vinpub
Just noticed this morning that the tail light was not working, so went and got a new bulb. Tail light works fine, brake light works fine with the rear brakes. But front brake lever is not activating the brake light. When I pull the brake lever I can hear a click of the switch, but brake light does not come on. Since the light is working ok with the rear pedal, it seems that it's either the switch on the brake handle or loose connection.
1. How can I check the switch on the handle?
2. Where would I check for loose connection. W/O wiring diagram, and knowing how the wires are routed it is kind of confusing. Can someone help?
Thanks for your help.
