pmmcanon
Meanwhile you're all sleeping (8 hours difference ) I continue with my test.
As this is a tough problem, that could have had very bad consecuences (fire...) I think I must descrive all in detail to get the max help from you but also not making anybody loose his time. I must say I really appreciate your expert help and advices.
My Background: I'm familiar with 2 strokes engines (race and street) and have a reasonable ammount of tools (good ones), but not much experience in 4 strokes, so sometimes I'll ask for detailed instructions in dismount/mount some elements.
The bike background: Fazer 600 S2 ABS 2008. The bike is stock but the silencers that are Mivv-Carbon, also installed a KN air filter. It has been stopped for 5 years, parked in a garden with a good cover to protect it but there are some parts with rust (as you can see in the pics of sparks) mainly due to condensation/humidity. It was parked with some fuel that obviously evaporate leaving a good ammount of mud inside the tank. First thing I did was cleaning the tank, then I found the pump was affected (the reason for this post) and changed it to a denso one, between this I found an R6 old Pump and used it to check if all the fuel injection system was ok, it worked. I mounted everything and have been driving 130 Km with some ocassional stalls (not very serious) mainly when the bike was cold, as soon it gets temperature it worked ok until the yesterday episode...
At this time I've checked the sparks (Pics attached) and now dismounting the injection system, but a little bit scared because the screws are really tight and surely with some glue coming from the factory. I remember I was told to use an impact screwdriver to untighten them but not very sure. I'm gonna stop at this stage to hear from you the better way of dismounting procedure (or any advice from your side).
I also checked the exhaust line and there are no leaks or hot gases getting out nowhere.
I'll wait for your instructions
KR
KR
