Marcelor73
The 2013 FZ8 will come with fully adjustable forks and a stiffer spring. Does anyone know if it's possible to do a FZ8 to FZ6 fork swap?
I love the R6 forks! Night and day improvement! They come with 0.88kg/m spring rates. I'm roughly 220lbs w/gear. To my surprise the OEM 0.88 works very well and I'm picky about my setup. I'd suspect you'll need to replace them with higher rates for >280lbs. Also these are linear rate springs vs the FZ progressive.
IMO too many here try to make up for the lack of damping by jacking up the spring rates. The stock spring starts at 0.75 IIRC, but because it lacks effective damping control for both compression and rebound too many make BIG jumps for spring rate increase and don't address the original problem of minimal control.
I guess this post is to advocate fork upgrades R6 or better and/or install emulators, cartridge kits as noted above when those forks are opened it. It literally makes the bike a joy to ride and safer too!
Bottom line; don't go overkill with the spring rates when its control of compression and rebound that need the most help!
I have two bikes, and the FZ is a toy for me. :BLAA: No track days just weekend fun, is the fork upgrade worth the $300 to $500. Is it night and day between the ride?
Yes, yes, it is!
