FeroFazer
Hi my riends. Pls I need advice. I want to make a light switch. What is the procedure? Please advise some wiring diagram or some photo
because of the fact that the motorcycle is weakly charging me for electricity.
where should i place the switch?
which cable relay should I cut?
T
I do not solve the stator of the motorcycle........ Pls.
how to make light switch?
answers only to the topic pls.
Here is my suggestion, rather than hack up your wire harness, simply remove the 20A headlight fuse. It will reduce the current draw by about 4 amps.
You SHOULD check the voltage at the battery terminals - both with the headlight fuse in place and with it removed. If you don't see at least 13.5VDC, your problem will not go away - you will have to address the charging issue.
Say hi to moose and squirrel for me.
OK, if you have a multi-meter please do the following tests:
1. Check the voltage at the battery with the ignition key in the off position. It should be around 12.6 to 12.8VDC. Do this test at least an hour after charging. If it's less than 12.6VDC, disconnect the battery terminals and charge the battery again. Wait an hour and check the voltage again. If it is still low, you need to replace the battery. If it now reads in the normal range, you have a parasite loss (a short) somewhere in the electrical system.
2. If the battery passes the first test, check the voltage as you start the bike. If the voltage drops below 11VDC, the battery doesn't produce enough current and needs to be replaced.
3. If the battery is able to hold a charge, and the voltage doesn't drop below 11VDC during a start, yet the battery goes dead while riding, then you have a problem with the charging system.
Let us know how you make out with the battery tests and if necessary, we can walk you through checking the charging system. It is common for a battery to fail (even a new battery) but uncommon for the charging system to fail.
