Help with Headlight?
RuskiMotorcycle
Austin, Texas
Hey All,
You guys have been pretty awesome so far with help, so I really appreciate it!
I'm going naked and I'm pretty set on a 7" single round LED headlight. However, electrical work is definitely not my strong suit. I'm not sure which numbers and specs I need to match up, if any.
I bought this - https://www.amazon.com/gp/product/B0167DQGGK/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
My guess is that it's as simple as grabbing the high beam wire, sticking it into the 3rd female port on with the low beam and ground female port, and plugging it in. No idea if that's actually how it's done though.
I attached picture to show you what the headlight came with. It's got two adapter pieces, which I'm also not sure what to do with.
And if anyone has good ideas for turn signals, along with where to mount them/the speedo/the horn, I'd love to hear the suggestions.
Imgur: The most awesome images on the Internet
Thanks!
trepetti
It's all good!
Northern New Joizey
The stock behavior of the headlights on the FZ6 leaves the low beam on when you activate the high beam, This is OK because the high and low are separate bulbs. So if you do as you suggest, moving the high beam wire to the low beam connector, then your LED headlight will work the same. Meaning one LED on for low beam, and both LEDs on for high beam. Look over the documentation to see if you must shut off the low beam when you activate the high beam. If you do, then will need to install one of the dual-headlight mods (like the Motogiro or the BD43) and simply plug in the H4 connector into new LED headlight.
