Kenward
Hey guys. Recently my left fork seal started leaking oil so while I'm in there fixing that I figured I'd upgrade the springs and oil while I'm in there. I ordered some 1.0kg RaceTech springs and just got them the other day along with the spacer, washers, 15w fork oil, new seals, and retainer clips.
I've done a lot of research on how to measure and everything like that, but my problem is that I won't have the tools to do it myself, so I have to take the spacer somewhere to have it cut. I was just wondering if anyone could give me an idea of what length I should cut them so I won't have to run back and forth between a shop?
Rider weight: 200-205lbs
With gear: 210-215lbs
With gear+bag: 220lbs
1.0kg Racetech springs
15w fork oil
I don't really have time for track days, but I'm more of a sporty rider so anywhere beween 25 and 30mm of sag should suffice.
Once again, not being lazy, I just won't be able to repeatedly tear down the forks to make adjustments. So if anyone has a similar setup or the knowledge to recommend a number I'd really appreciate the help.
Thanks guys!
15w fork oil
Thanks guys!
