FB400
The H4 contoller has 2 plugs? was this adapted from a setup for a car? guesingg you would just abandon one of them?
I noticed you didn't black out the stock reflectors. I've seen others who have. Is that purely style, or related to function in any way?
It's purely a style preference. The reflectors will receive literally no light to reflect anything with these projectors.
Looks nice bro. I'm assuming you figured out the wiring for activating the high beams then?
hi sweeney_todd
nice mod you got, you got the ebay projectors with angel eye?
i am having some issues, could anyone help me out.
1) my ccfl at left side (low beam) does not have a complete ring of light, what's the problem with it?
2) low beam seems to flicker and sometimes totally turns off.
3) where did you mount the ballast and controllers? did you use 1 controller only? my setup have 2, trying to figure out how to remove 1, my headlight is damn heavy now, and the wiring is in a mess.
4) how do i set/adjust the light throw height?
did you ever figure out what to do with the other set of hid's??? i feel a dibs comming on!!!
hey, yes i I bought them on ebay, the link is on the first page.
Would be helpful if you took some pics of it. I'd check the cables, sounds like a connection issue.
How did you connect the rings? I took a small piece of isolation off the marker light cables and connected to the controllers for the ccfl rings (because I used two small separate controllers for the rings)
I used a velcro tape to attach the ballasts and the controller to the sides of the fairing. You can always use slim ballasts that take less space and are probably lighter. I'm gonna get a pair soon
Yes I used one controller because the H4 kit came with one (it has two outputs for the ballasts and one h4 type input), the H7 kit had two for each bulb. So I had a option: 2 h7 controllers or one h4 controller. I doesn't really matter, I just figured i would take less space. Im guessing your controllers have one output for the ballast and a 4pin round cable for ccfl and hi beams. Here is the type of controller I used:
35W HID H4 Hi Lo Low Bi-Xenon Controller Relay Harness | eBay
You adjust the lights the same way, using the bolts that are on the back of the headlight. its in the manual.
i have 2 controllers right now, i saw your post, you have only 1 controller? how is that done?I think you'd need a controller for two bulbs.
about the angel eyes. It's weird. One of the members of this forum had the same problem. it's Boneman, but I don't know if he fixed it. this is his website:
Welcome to Boneman's FZ6 Site
How have you powered the rings?
and Halogen hi beams, not without some seriously seriuos fabrication.
The controller I used is different then yours. Here is what I have:i have 2 controllers right now, i saw your post, you have only 1 controller? how is that done?
thanks for sharing, i seen his website before but i didnt notice his setup was having the same problem.
the angel eyes are powered by the bike battery, as shown in the 1st picture just now. all wirings are seen relatively clearly there.
ok, so i guess i should give the idea up of having a normal halogen for hi beam..
