Installed Yamaha LED indicators having problems help :/
HarmfuL
London
So i recently bought some Yamaha LED Indicators for my bike and started off by installing the rear set first (being bit more tricky I thought). The blinkers come with a resistor so the flasher relay didnt need to be replaced. I tested them and they worked fine on the rear, then installed front set and tested all together and now the indicators dont work, hazards, front light and rear! So I checked the fuses to see if I had blown any and they were all fine, went over my wiring again and they were all fine aswell?
Any suggestions or advice would be brilliant
Cheers
You can buy and electronic typre flasher relay and it will work regardless of the combinations of loads within a wide range compared tot he OEM flasher relay.
Super Bright LEDs - Electronic LED Flashers Specifications
LF1-S-FLAT at the bottom of the page. Now you can also get rid if the resistors which create heat and use extra current.
