Is This FZ6 Worth $500 OBO?
FZSexy
California
its a really messed up bike. look and see
Does the motor run? How many miles? That poor fizzer's been bashed! If you're interested it would have to run then maybe part out the motor but remember it'll be a tear down for parts or a big shipping bill and check the mounting points from engine to frame and swingarm. Also research that the bike has no lean or DMV/ticket charges against it. :confused:
VEGASRIDER
100K Mile Member
RENO, NEVADA USA
I could use a new side stand. Mine has essentially worn out, not much meat left on the base. Bike is not worth $500, maybe $150. The rear wheel looks like it's in decent shape.
kinderwood
Frederick, MD
Looks like the stator cover took a hit and is cracked open or been removed. The coil is showing, it should be attached to the cover, ie if the cover was removed it shouldn't be there. Won't run like that. Look for cracks or holes around engine crankcase castings.
FZSexy
California
ad says 19,000 miles. i am not buying it as i have nowhere to put it. if i had a garage you never know, though. just to take a look inside of it all
but don't these bikes have certain components that would be useful to a DIYer or even for sale? what of its ecu and FI components? certain misc hardware, brakes, sprocket....and other bits and pieces? wheels? the ad says "would part it out myself, but no time."
just what parts, though?
FIZZER6
The Angry Blue Mantis
Virginia
the side cover looks like it's cracked off. If it lost oil while running it could have engine damage. Do FZ6's have tip over kill switches?
The rear wheel looks usable as may be the front brake rotors if they aren't bent and the brake calipers. If the engine is toast there is no much else useful on that bike other than the sensors and switches.
ShoopCE
Parkersburg, WV
I agree with the comments about the side stand and brake parts.
But I would not want to take any risk on the engine. The rear tire is bald in the center with LOTS of tread on the rest of the profile. I'd suspect the tire got that way because the owner liked to do burnouts. All sorts of engine and maybe transmission problems would result from that.
R.I.P.
aclayonb
New Albany, IN
Might be able to pull of the wiring harnesses, throttle bodies, some internal engine components, brake calipers, some other fiddly bits, and straighten the forks. You'd be hard pressed to get your money back though. That would take a while of patient selling on fleabay and a couple desperate buyers.
FZSexy if you want to rebuild it, I'll toss in an OEM plate holder and radiator guards. Blah
They're powder coated black already! Hope thats OK!
FIZZER6
Virginia
I hope you have never or known anyone who has actually tried to straighten and reuse bent forks! The integrity of the fork is toast once they are bent like that.
VEGASRIDER
100K Mile Member
RENO, NEVADA USA
The Yamaha clamp on the handlebars is still good. The earlier models didn't have them and is a nice addition in terms of looks instead of having it just be a bare piece of bar.
How does a bike get in that condition? Was it in Baltimore?
Have you considered entering this bike into the bike of the month contest?
aclayonb
New Albany, IN
Knew a guy that professionally straightens 'slightly' bent forks. And yes, they rode fine with no issues. I didn't even know it was a thing until I couldn't find a good, straight set for a old Honda.
kenh
Ride Like Your Invisible!
Premium Member
Milford, MI
When I saw the rear tire, I suspected the former rider exhibited some squid-like tendencies. That must have been some wild ride to cause that much carnage. I seriously hope nobody was not hurt too badly. [emoji33]
Sent from my DROID RAZR HD using Tapatalk
