Leak from under the stator!
Motobol
Nevada
Every time I park my bike there’s always a couple drops of oil or something on the ground right beer the stator. The underside of the stator is wet. How do I replace the gasket or what needs to be done?
Is the bike new to you? Any recent tip overs?
Anyway, I'd clean it real good then monitor for exactly where it's leaking.
It's somewhat unusual to leak un-less the bike was dropped hard..
Very likely, you need a new stator gasket. You'll also need some sealer for where the wires go into the case.
The job can be done W/O dumping the engine oil, just keep the bike on the center stand.
BTW, posting a picture helps too..
Motobol
Nevada
Yes the bike is new to me and it has been dropped. Should I put the sealer on the outside or inside of the stator case?
Just use the sealer on where the wires enter the cover (should be a small rubber grommit).
Do NOT put sealer on the gasket or gasket surface.
As the bike is new to you, been dropped and that gasket almost NEVER LEAKS, inspect that cover closely.
**I suspect it's cracked (hair-line crack or otherwise) and will need replacement. Hopefully the main block is not damaged.
As noted earlier, clean it spotless and keep a close eye on where the oil seeps from.
