I have always felt to mechanically inept to have a go at this but tonight whilst doing my clutch cable I thought, “Well it isn’t raining I’ll give it a go.
I had not had any issues at all with sticky throttle. The results were very surprising. If you have not done this and ride in the wet. Get your spanners out.
Unscrew throttle twist grip casing (expert me, at terminology)
Notice the rust in there OMG.
Three screws all told holding the twist grip on to the bar.
I was totally shocked by how rusty it was.
Remove bar end; I suppose this should be done first.
Slide bar off
I cleaned the rust off with WD40 and then greased it. It will need several cleans before it is back to anyway near its original condition.
Pop the throttle out and push the cables through. Yamaha have designed this brilliantly. They obviously had me in mind. I got mixed up with the opening cable and the closing cable. They can only go back one way though.
Use the cable grove as a guide to lubricate down. Initially I was unable to pull the cable through but after a few minutes the oil penetrated.
Slide bar off
