My Fender Eliminator How To
phranK2k11
Chat Camper :)
West Virginia
First I'd like to say this "How To" is more of an exercise on my part on how to work and take pics that are usable with a "How To" thread. That being said I think these pics would help get the job done and I hope someone gets a lil use out of them.
First you'll need to remove your seat.
http://www.600riders.com/forum/attachment.php?attachmentid=34984&stc=1&d=1302653927
Now remove the single allen bolt holding the left side (as seated) tail trim on.
http://www.600riders.com/forum/attachment.php?attachmentid=34985&stc=1&d=1302653927
Remove the tail trim to access the turn signal and tail light wire connections.
http://www.600riders.com/forum/attachment.php?attachmentid=34986&stc=1&d=1302653927
Unplug these connectors.
http://www.600riders.com/forum/attachment.php?attachmentid=34987&stc=1&d=1302653927
Press to unlock the snaps on the wire cover and remove it.
http://www.600riders.com/forum/attachment.php?attachmentid=34988&stc=1&d=1302653927
Remove these 2 allen bolts under the muffler
and 2 bolts (only 1 in pic) between muffler and turn signals.
http://www.600riders.com/forum/attachment.php?attachmentid=34989&stc=1&d=1302654056
Looks like only 6pics allowed per post so there will be a part 2.....below
Part 2
Your stock fender will now drop down carefully fish out the wires.
http://www.600riders.com/forum/attachment.php?attachmentid=34990&stc=1&d=1302654901
This is what your pile of parts should look like at this point
http://www.600riders.com/forum/attachment.php?attachmentid=34991&stc=1&d=1302654901
Mounting the new fender is easier done before putting lights/plate back on.
http://www.600riders.com/forum/attachment.php?attachmentid=34992&stc=1&d=1302654901
Separate turn signals, tag light, and plate from the stocker.
http://www.600riders.com/forum/attachment.php?attachmentid=34993&stc=1&d=1302654901
When replacing the wiring be sure to zip-tie it safely away from the muffler.
http://www.600riders.com/forum/attachment.php?attachmentid=34995&stc=1&d=1302655021
After reconnecting the light plugs,
http://www.600riders.com/forum/attachment.php?attachmentid=34994&stc=1&d=1302654901
Stay tuned for part 3
Silly question but does everybody get chain oil up over the exhaust and upper tail of the bike?
never had that with another bike- is it a poor design? I am sure I am putting no more chain oil on this bike than any others
I get lumps of tar from the road and bits of oil. It's a killer to keep clean if you don't stay ontop of it. Which unfortunately I dont. :(
is it possible you can tell me how to put original stock signal to the fender whick kind mounting is easy to do some picture will be help full.i have ordered aftermarket signal but wants to keep stock.Thanks in advance
I am also having this issue, I cant tell by your pics how you mounted the stock signals
Edit: I see your FE kit is different than mine, it looks like you have the same mounting hole that is on the stock fender for the turn signals, mine is a 3/8" hole slotted about 1/2 an inch vertical... now I am really confused, I wonder how anyone would be able to mount a stock light with this type of mounting hole
LOL ummmmm in actuality... my FE kit is TOTALLY WRONG! will not even fit into mounting holes...
Did you have a pain in the @ss time removing the two bolts right/left of the stock fender (half way covered by exhaust)? I don't know if its a '09 thing or something slightly different perhaps the way the dealer put my bike together...
That took 50% of the time alone... could barely fit any wrench, key, tool in there...
I thought of having my 3 yr old sitting on the bike too for a final pic, but I didn't want the NY authorities knocking on my door the next day :Flash:.
Yes they were a PITA i found if you loosen them then wiggle the fender while turning em with your fingers they come off pretty easy. I had to take em off and put em back a dozen times so i had to find a better way too. Hope you read this before its too little to late.
