paul1149
Riding with the King
I was happy with the stock Bridgestones, but the rear wore out at 8500 miles. So I ordered up a new Battlax BT021 from motorcycle superstore. The tracking page said it would come on the 9th, so imagine my surprise when it showed up today.
I think there's a learning curve for changing tires. But I said a prayer and lit into it. The wheel came off fine. The bead broke with no problem. Getting the tire off the rim was another story.
The 8" tire irons were a mistake; 12" would be much better. And now that my rim paint is pretty chewed up, protectors will be mandatory next time.
The hardest of all was getting the second side of the new tire on the rim. It literally took all my strength. On youtube, guys almost push the tire on with their bare hands, it seems.
I made the mistake of not lining up the weight dot with the valve when I mounted the tire. I would spin it in place afterward, I thought. Nope; ain't gonna happen. When I realized that I forewent even balancing the tire, figuring the whole thing was a crap shoot at that point anyway. And the stock installation didn't have any wheel weight either. So I put the thing together and back on.
In doing so the sprocket just fell off. It was then I realized I didn't have to fight the sprocket all that time. Next time it comes off by design.
Anyway, the tire is on and I scraped it in this evening. Everything seems fine. I don't think it needs weights. I'll probably give it a good run tomorrow and make a final determination.
There's some water in the tire from my soap solution, so I'll change the air tomorrow to help dry it. And I'll touch up the paint on the rims. I guess I'm in the market fon a 32mm socket, since one can't torque the axle nut using the factory road kit wrench.
All in all, I'm glad I took this job on. I learned something and I saved $70 in the process.
I'm not a very aggressive rider, but I like the Battlax. It's a dual-compound tire, meaning the underbase and center is hard rubber for long wear and the shoulders are softer for more traction in the turns. A very smart way to go.
Peace,
Paul
Peace,
Paul
