smallblock450sl
Don't forget to put dB killers in your exhaust!! :BLAA:
I want it quite, what are DB killers?
Looks good, but wouldn't the drastically different header lengths cause problems with uneven cylinder pressures?
Awesome!!! I have a similar plan of buying an off-road type kart frame and then installing a two stroke 600 cc triple snowmobile engine inside. Sadly my wife told me I was nuts and already have too many toys:spank:
Very cool!
Is that a 9" ford rear end and did you figure out how the rear end gear ratio will work out?
You going to make a foot operated clutch and make the shifter hand operated? The actual shifter should be fun to design and build too...
Don't you need a panard bar to keep the rear end centered?
Typically the fuse burns out before the ecu frys! Atleast on the training bikes at Awesome Cycles that I work on the FZ6 might be different!
I also have a good 06 ecu if you need one!
The nature of solid state circuitry is very unforgiving out side of it's range of design and if not protected can be damaged far before the fuse ever blows. Many integrated devices fail with out ever blowing a fuse. Reverse polarity is one of those conditions that a fuse can not protect. What can typically happen is a solid state junction or component fails and conducts high current between positive and negative, in turn blowing the fuse on the circuit the fuse is rated to protect.
The idea of the fuse is to protect other parts of the system from further damage. One example would be fire. The fuse is only designed to blow open when a a specific current overload occurs but can not protect components from incidents of reverse polarity or other anomaly. The component itself would have to be able to conduct in either polarity or be designed to not conduct current in a reverse direction to protect itself.
Many small current circuits are designed to not conduct current in the event of reverse polarity. This is easily done using a diode and essentially reverse polarity is none existent to that circuit.
Ironically or PLANED, the gear ratios are not that far off. The MASS of said cart may be a bit rough on the FZ clutch tho!
FZ final drive ratio is 46/16= 2.875:1 Our rear tire is roughly 25" in diameter.
Typical final drive cage ratio for non-performance DD = 2.75:1 to 3.50:1 for sportier modes. If you can keep the tire size below 23" you should be OK once you get it rolling. Granted the 9" is massive over kill here, but there are tones of gear ratios available. Like a set of 4.56:1 gears would be cheap and extend the life of the clutch dramatically.
Q? Have you weighed it yet? Good Job! Keep it up!
If the RR was in place it likely too k the brunt of it current wise. It has the diodes and if im not mistaken would be in a clamping mode shunting the current to ground. Does that seem plausible seeings how its being reverse biased? Time will tell what may have been hurt. Mainly the ECU, RR and starter-lockout relay are the active components that wouldn't care for reverse bias.
Wow, thanks for the posts:thumbup: There's only one wire lead that attatches to the starter, can anyone tell me exactly where it attatch's at the battery area?
You sound like my Stepdad most of what you said went straight over my head! I have some Oscilloscopes you might be interested in and a function generator!
I never did pick up the electronics and the indepth repairs or how exactly they work! Tracing shorts and the other minor stuff I can do no problem! My stepdad used to repair circuit boards and replace chips and what not he was a genious!
