06fiz600
After looking at the stock dyno chart and the gear ratios, I've come up with ideal engine speeds to shift at for peak performance. :rockon:
The owners manual has these ratios:
1-37/13-2.846
2-37/19-1.947
3-28/18-1.556
4-32/24-1.333
5-25/21-1.190
6-26/24-1.083
final-46/16-2.875
The graph above is a matlab code that plots the wheel rpm (=engine rpm*gear*final drive) by the wheel torque(rear wheel torque data*gear*final drive)
example: in 1st gear holding it out past 1630 wheel rpm puts a lot less force down on the road
wheel rpm intersections.
wheelrpm*gear ratio*final drive.
1630
2289
2803
3217
3577
Shifting:
1-2
shift @
13337rpm ---> 9124.1rpm (resulting rpm)
2-3
12813rpm ---> 10240rpm (resulting rpm)
3-4
12539rpm ---> 10742rpm (resulting rpm)
4-5
12329rpm ---> 11006rpm (resulting rpm)
5-6
12238rpm ---> 11137rpm (resulting rpm)
1-37/13-2.846
2-37/19-1.947
3-28/18-1.556
4-32/24-1.333
5-25/21-1.190
6-26/24-1.083
final-46/16-2.875
1630
2289
2803
3217
3577
Shifting:
1-2
shift @
2-3
3-4
4-5
5-6
