Before I get into the work that I just did, I've got to give a major shout-out to Brad (dako81) for the very nicely machined fender brackets and spacers. If you're considering doing the R6 fork thing, and you've got an '06 or older, you need to contact him for a set of his goods. Great stuff!
I just got my bike put back together yesterday. Checked all the fittings one more time today with the torque wrench and went out for a quick ride.
I installed:
- r6 forks and brakes
- fz1 bars
- ASV (long) adjustable levers
And I had a bunch of stuff powder coated: pegs (front and rear), rearsets, bars, and top crown.
I had the header ceramic coated black, too.
I like the look of the blacked-out bits. And from the short ride that I did today, it seems like the ceramic coating is going to help with the ambient temps on the bike -- maybe it's a placebo effect, but the bike felt a little cooler at stops.
While I had the bike torn down I also went ahead and did the service to the swingarm bearings. They appeared fine, plenty of grease, but I re-packed them just the same.
The bike feels pretty good. I set the forks up according to an article that I found on SBN (I think...), I found it somewhere in the midst of an R6 fork mod discussion. I'll have to give it a ride or two before I make an tweaks to the current settings.
The fz1 bars feel a little different. (duh, I know) All that I'm saying is that I will have to ride with them for a little while to see if I'll keep them or go back. I'm not knockin' 'em, just going to wait to see if they suit me.
I've got rizoma bar ends on order to replace the stockers.
I like the ASV levers because of the ability to adjust the reach on both sides. I had the stock brake lever adjusted all the way in but was always frustrated that the clutch couldn't be adjusted. Problem solved. Granted, expensive answer to the question, but I do like how adjustable they are.
Here she is...
Here's a stock '06 for comparison. And the article on set-up that I mentioned.
I installed:
- fz1 bars
Here she is...
