weehe
Good to know on the PC, I thought it was a ecu flash. That is good to know on the fuel pump dying. The first thing I asked was if the tank was replaced because of rust and was told there was no rust. I am guessing it was probably run dry or had really old gas as it sat. Anyway to see if there is a leaking injector? It starts up fine and there are no misfires. Also the plugs all looked uniform.
I will check out the AIs and CO values this week/weekend and let you know what I find. And will see if I can get a video. Then I'll do a TB sync when the carbtune comes in. After that I'll start exploring the more time consuming/expensive options.
Another side question. If I remove the cat and make the stock exhaust freer flowing, would I need a PC to make sure I'm not too lean or can I adjust the CO values. This is for once the problem is fixed lol.
