texcollect
Crotchety Old Fart
This isn't strictly an FZ6 mod, but bear with me.
I recently bought a 2007 FJR to replace my FZ6. I have a Motodynamic integrated LED brake light installed on the FZ6 and was so convinced of its safety benefits that I wanted to do the same thing on the FJR, but nobody makes that same thing for an FJR.
Google is your friend and I cam across this (Supa Brake 2) from ViziTec.
Some of the features I liked about it was the fact that if it is triggered it has a variable "grace" period between brake applications so that it isn't constantly flashing, but does have a force flash retrigger. This feature also gives out more pulses the longer it has been since the last brake application. It has a "decaying flash" in as much that the flashes get longer as the cycle goes along.
The unit is configurable with both the flash rate and grace period algorithm so if you use incandescent bulbs you can have the flash rate slower (the bulbs don't react as fast !!) and if you use LEDs you can have a faster flash rate. There are 3 settings available for both.
Anyway I ordered one and it came in real fast. Since it comes with both a male and female connector already installed installation truly is plug and play. I removed the side panel, plugged it in and was all done in about 10 mins. Originally I had is set for a slow flash rate, but when I also swapped out the bulbs for LED 1157s I switched to a faster flash rate.
I have emailed back and forward with Bernard that runs Vizi-tec and he is extremely helpful if you have any questions. If you use the code KXX5TS you should get 20% off your order.
I have no commercial connection with this company, but their product is easy to install, works and they are offering a discount.
