tcmalker
Banned
This is so simple it can literally take 20 seconds.
1. Pull out black connector from highbeam side.
2. Flip open cover. Pull the yellow/black wire connector out and put that in empty connector spot.
3. Close cover. Push black connector back in.
Results:
1. Low beam mode stays the same, single low beam.
2. 'High Beam' mode = dual low beams
Benefits:
1. Fastest dual headlight mod out there! Also cheapest.
2. No soldering, crimping, etc. Look factory. Can be convert back & forth with ease (warranty issues).
3. Same weather/elements protection.
4. No worry about extra electrical loads. You always have option of going one beam only if you ever have charging issues.
Cons:
1. Lose high beam.
Results:
Benefits:
Cons:
1. Lose high beam.
