urbanj
One more thing is the fz6 uses a speed density instead of a maf sensor. There is no way for speed density system to adjust or compensate for fuel or timing for boost pressures. It would have to be changed to a maf. Or you could preset it at 6 psi, but will be rich on the bottom end.
I don't know any top knotch standalone ecu's that run mafs. maf's create a huge restriction. But then again at 5psi you most likely not be able to see it. A 3 bar map sensor will be good for more boost than anyone would throw at our bikes.
I quickly searched and this is the smallest turbo that garrett makes which they say is good for motorcycles and 130hp. But even at a pressure ratio of 1.43 (5psi) its barely on the compressor map, regardless of how much air the motor pushes. off the top of my head our motor at max VE pushes around 7 lbs/min. and almost 10 at 14000rpm.
TurboByGarrett.com - Catalog
Actually I was looking over the site and I recommend reading the expert tech section or just from the beginning if you are learning.
