arronjackson
BC
I don't like to reuse gaskets, so when I do mine, I purchase a new:
Valve cover gasket
Timing cover gasket
Water pump drain crush washer
CCT gasket
Also a good time to replace spark plugs if you are so inclined.
You wouldn't happen to have part numbers for those would you :oops:
Don't know your year bike but put in your bike info and you can look up:
arronjackson
BC
For those looking to do this job in the future the parts you'll need are:
Valve Cover Gasket - 5SL-11193-00-00 - 52 CAD from the dealer
Cam Chain Tensioner Gasket - 4FM-12213-00-00 - $4
Oil Pump Cover Gasket - 5SL-15456-01-00 - $20
Water Pump Crush Washer - 93210-32172 - $7
Andrei.kimoi
Romania
Greetings,
I have a 2004 fz6s with approximately 58,000 kilometers on it, and the valves have never been adjusted. Upon disassembling the engine and reaching the shims, no markers can be observed on them.
What do you advise me to do?
Has anyone else encountered this issue?
Does anyone know what markers the original shims should have?
Andrei.kimoi
Romania
I used a digital caliper to measure the old shims (and the new ones).. And then change out accordingly:
Thanks, I see that I didn't told that some shims are out of their original form ( not a perfect cylinder, or a perfect round form). And because of that measuring with a digital caliper can be faulty.
