Water pump, strange noises
2007Z6ALL-LED
Southern California
Would you or someone show me how to remove the inner half water bump housing case? I heard someone said to use bumping air to push it out..but no idea/imagination how it can be forced out.
I'm planning to just replace the O-ring part# 7 but in case to have to remove everything to rebuild the seal just like you..(mine doesnt have the squealing sound yet but sip-leaking-turn-dried below and no obvious leak at all). I just want to ensure to replace it in time so the water won't get in the engine to cause more damage
Thanks so much anyone's response on this!
UPDATE :D - REPAIRED
My experience:
picture.php
Starting here
picture.php
Draining system, thought this was a cool pic, also removed inlet and outlet hoses.
picture.php
Outer cover removed, nothing strange.
picture.php
Pump removed, tight fit on that mounting O-ring. Used compressed air between inner half and engine to loosen then pulled right out.
picture.php
Inner half drive side view.
picture.php
Disassembly; oil seal, pump seal, oil O-ring & bearing, housing gasket & impeller with rubber damper & holder installed, circ clip.
picture.php
picture.php
Seal removed, noticed rust formation.
picture.php
picture.php
Cleaned surfaces with degreaser and Fast Orange hand cleaner.
Assembled per Service Manual. Manual error at step 3, fails to mention rubber damper & holder are one piece. Refilled system, no leaks, started, up to temp, topped off and took it for a ride. All done.
