- Joined
- May 8, 2008
- Messages
- 15,358
- Reaction score
- 1,606
- Points
- 113
- Location
- San Diego, Ca.
with no load it will rev to redline
thats whats getting me tho, it hits 8K in first and 5th, there is less load in first than fifth but they both only go to 8K
Try this just to make sure it's not related electronically to the clutch safety signal.
Start the bike and pull one of the spade connectors off the clutch safety switch. Tape it so it doesn't ground out and take it for a ride to see if the motor opens up.
We've also seen crosstalk through connector plugs between the speedo signal and the TPS signal interfere and limit the FZ6s fueling.
I've run across 2 such cases on the forum. The bike runs fine but if the rear wheel is turning the speedo signal interferes with the TPS signal.
Pull harness connectors, inspect pins, wash with cold water, blow dry with compressed air. spray with WD40, and plug back in.
I've seen this more often on UK bikes that were naked and got exposed to salt water/spray or dust. The salt especially causes crosstalk/conduction of small signals the ECU uses and the bike will not run right. Cold water is the best way to rinse salt out of the connectors. Do not use contact cleaners first. They will tend to help bond the salt because of oils. If you use oil based cleaner you'll have to use another type oil based cleaner to get the salt out. The salt will emulsify with water and rinse out. Then dry w/compressed air and addition protective spray. Water first!
Have you done the TPS check yet? Do it with the rear wheel up and look at the numbers at full throttle. Turn the rear wheel at the same time. Number changes? Crosstalk...
Please see my post #27. You can easily do this procedure. If you don't diagnose the problem and act on it, it will probably still exist...
