This must be an FZ6 thing... I just checked the FZ1 manual only to find I DO have a clutch? WTH?!?
Anyone have instructions on using this clutch thingy?![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Anyone have instructions on using this clutch thingy?![]()
Clutchless up from 3rd and above, never down the box, when changing down at speed, ie, decelerating, the back wheel can still lock up, a "blip" of the throttle whilst the clutch is engaged can raise the revs to counter this. Takes a bit of practise.
There's no need to get the revs right on the up-shift, just drop the throttle and change up :thumbup: if you "load" the gear shift with a bit of "weight" from your foot just before dropping the throttle it seems to just slip into gear. Gear changes are pretty "seemless" doing this from 3rd up, it can be a bit "clunky" from 2nd to 3rd and 1st to 2nd I've found is a big no-no.
Weird .....kinda sounds like my honeymoon! !!!!Most of the time I do use the clutch... Just a little though. With two fingers, I pull the lever until I reach the middle in order to barely disengaging it, preload the shift-lever with my foot and drop the throttle, slips right in...
weird .....kinda sounds like my honeymoon! !!!!
question on clutchless down shifting:
do you just put pressure on the shifter, and then blip the throttle? will it only change gear once the revs are correct like on an upshift?
