- Joined
- May 8, 2008
- Messages
- 15,358
- Reaction score
- 1,605
- Points
- 113
- Location
- San Diego, Ca.
No Pressure.
No Fuel.
No Run.
It needs fuel. Test the pressure!
Battery is very happy - Cranks SO fast! Plugs are not your issue as stated before. It wants fuel. Find out why it has less than it needs!
Hmmm..... Do a compression check? Maybe the cam chain jumped and that is why the bike was on the side of the road with the bike thief in the first place? I hadn't seen the video and just watched it. When I heard that fast cranking..... Do a compression check. If the compression is bad you may have to reset the cam chain. Hopefully only off a tooth or two and the valves are good...
