Yeah, we want to know what happened
Since there have been a few great opinions so far, if you haven't checked it yet...FWIW, from experience recently, I second taking the airbox off in any case, and checking all of it. You said you were going out to do that, last post. Yes it sounds like a leak, and yes, the airscrews being too far out of adjustment could cause it. Use the diagrams that were posted to check all lines. I had a few lines where integrity looked fine to the naked eye, yet leaks were still present. Check ALL lines for leaks, and then proceed.
Reason being, it's not hard to do, and you're going to want to cross them off the list. After that, homemade manometer will get you close (follow Scott's 3/4 turn on #1 advice) enough for now, but my experience was that real gauges are superior to any fluid manometer. Whether the Vaccummate/Carbtune vertical type, or classic round gauges, it is important to have something which responds to changes quickly. This way you can set it and be done, as opposed to watching your homemade job change more and more slightly after each adjustment as your engine heats up past safe. You'll see when you use it, if you haven't already.
Thick fluid (like the 2 cycle oil in most online examples) = safe but slow to respond so very hard to get them really balanced. Thin fluid = not so safe, faster, still not as good as gauges. So yeah......
Also, make sure that the idle screw is not screwed in or out all the way. About 7 turns out (half way) is a good starting point. Just as you can't adjust idle with air screws out of whack,or vacuum leak, you also can't adjust the air screws properly if idle screw is all the way in or out.
Check everything for leaks.
Idle screw half way out
#1-4 air screw 3/4 out
Start and set idle close to 1300 using idle screw
Sync #2-4 air screws to same vacuum as #1 is
Make sure you still have good adjustment of idle screw (say 800-1600 RPM)
That should get your idle back AND give you peace of mind that all is well. Then when you get real gauges or meters, easy to just hook up and do the sync again.
Loren
