It is my understanding that a NB sensor is limited. Hence the need for WB sensors which that article didn't speak too or even mention. Good info tho! Thx!
Miscommunication? I ask this as you know the Piggyback hardware can not stand alone so it can't do the job of the ecu fueling.... and to my knowledge no one has invested in ignition modules for the fz as there would be little return on such a product.
From the pdf link you posted...
ALTERING MAPS USING SOFTWARE
The values in the map represent a percentage of fuel change over stock. A value of 10 in the map indicates at that throttle position and RPM range the vehicle will be 10% richer than stock. If the value is -10, then it would be 10% leaner than stock. You have the ability to fine tune your fuel curve by altering these values. The Control Center software allows a value of +250 to -100 in each cell.
- looks like you can but it gets into dangerous territory without a means to sniff the tail. Too lean and bye bye engine. Best you could hooe for hear is a detailed map of what the stock ecu is mapped at and use that as a safety net. I always ment to put a zero map into mine and just record what the oem ecu is really doing. From the maps I've made I see it plays on both sides of the fence from 4k to13k going rich and lean then switching back.
