RJ2112
- Joined
- Mar 25, 2009
- Messages
- 2,108
- Reaction score
- 23
- Points
- 0
- Location
- Dahlgren, VA/USA
Just did 20 miles (mostly highway at 75 or so.
The screen is not short enough
Not nearly as good as going completely screen-less. I could cut about another inch off (if I flatten out the top), but I don't even know if it's worth it. I have a feeling it'll still push the air flow too high.
If you look at most other bikes that have a half fairing, you'll notice that the screen 'floats'. Your '07 has the much simpler mounting system, right? Just a series of bolts along the sides of the screen?
An experiment to try, to see if this technique would work on the FZ6, would be to mount the screen 'outside' the fairing, on shims, so there is a gap all the way along the edges. I theorize this would only require (for the temporary experiment) longer bolts, and some plastic washers to produce the gap.
The DL 650, er6, most BMW screen designs have all gone to this format. The idea (I believe) is to allow a LOT more air to flow around the screen to reduce the pressure difference between the front and back. More airflow will reduce the vacuum, which is what sucks the buffeting towards your head/ears.
