NOTE: A new battery usually comes 80% charged and NEEDS TO BE FULLY CHARGED (on a tender) before being put into use. It will still work without the charge but the life of the battery WILL BE LESSENED....
Interesting. Not really completely applicable, but I just replaced my OEM FZ1 battery with Shorai (Lithium) and read all of their directions and FAQ.
"Shorai LFX batteries are pre-charged to approximately 90%
of capacity. Therefore it is not required – nor generally
recommended – that the batteries be charged before use in
your vehicle."
Q. Should I use a battery tender?
A.The short answer is "only if you really need to". Most powersports enthusiasts have gotten used to hooking up a tender to their lead-acid batteries, all the time. Shorai LFX have much slower self-discharge than the best lead acid do (1/6 to 1/7, on average), they do not sulfate as capacity drops, and they are the ultimate "deep cycle" battery, which means that they can still crank your vehicle even if the remaining capacity is quite low. Therefore most riders will not need to use a tender at all. Even a charger or tender uses energy you have to pay for, and there is always the possibility that a charger or tender can fail in some way, so if not really needed the best practice is to not use one.
A fully charged LFX can sit for a year or more and still retain adequate starting capacity, without damaging the battery. As such, any vehicle which has no current flowing when the key is OFF should never need a tender. At most it should be charged every 6 to 12 months, depending on the average storage temperature (cool storage is much better for any battery). Many older vehicles and most dirtbike/atv fall into this category.
Newer vehicles may have a significant draw even when the key is OFF, to maintain clocks and computers, etc. In this case we expect that a few hours of riding per month will be all that is needed to avoid tending. If you know that you will go a number of weeks or months without riding, you can either attach a tender, or disconnect the negative cable from the battery. In any case, during storage you may use the voltage chart above and an accurate voltmeter, and consider recharging when the battery is around the 50% capacity remaining mark, or above.
