MrMogensen
... That's me!
In Yamaha Factory 2004 manual it states...
A. Fill the brake fluid reservoir to the proper lev- el with the recommended brake fluid.
B. Install the brake fluid reservoir diaphragm.
C. Connect a clear plastic hose tightly to the
bleed screw.
D. Place the other end of the hose into a con- tainer.
E. Slowly apply the brake several times.
F. Fully pull the brake lever or fully press down
the brake pedal and hold it in position.
G. Loosen the bleed screw.
... and so on...
Is it really important to install the reservoir diaphragm (the black rubber thingy) between pouring in new fluid?
Why isn't it just like on a car? I don't have to keep the lid on the container while bleeding brakes on a car...
bleed screw.
... and so on...
