RyanMR2
I'd be in for one.
Hey, any updates?
Just as a heads up I went ahead and ordered a clutch slave lever from Ron Ayers
5VX-16340-00-00 I believe it was this one!
Yes, that is the past number, 5VX-16340-00-00, about $12 plus shipping.
I'll look up the other part number for the bracket. Basically you need that lever and the bracket that holds the cable.
If you mean the bracket with the pivot at the end of the lever, the fiche at Ron Ayers shows it to be included with the lever (it does not list a separate part number for just the bracket). Do you mean another, separate bracket?
Killernoodle is also going to modify the clutch cable holder, which is part no. 5VX-15441-00-00, cost about $6.
Can you fabricate the clutch cable holder too? I've been calling around, and the levers seem to be available, but not the cable holder, and there's no estimated availability date listed.
