nthdegreeburns
30 minutes into a stop / start commute in suburban Atlanta, I get to a major intersection in the left turn lane. Four lanes, both directions, and I notice the check engine light (CEL).
"What's that?" I wonder. I decide to hit the kill switch (the mistake) to cycle it on / off and see if it resets it. Next thing I know...
...I'm pushing a dead bike (won't start) from the left turn lane across 2 lanes up onto a sidewalk. I'm stranded. My first bike breakdown.
CODE 46
A few things to note:
I switch the bike on / off -- the speedo is indicating a nice big "46". After making some hasty calls for some help getting the bike trailered (if need be), I pull up this site and the PDF manual on my iPhone and find this:
Code 46 - Vehicle system power supply - Power supply to the fuel injection system is not normal.
So -- I've not had the bike on a tender much since I replaced it, because...effort. And I've not been riding much because of work, baby and weather. Perhaps the battery is the problem.
The Fuse Fix
I had a friend join me and help me guide the bike off the rather bad sidewalk so I didn't drop it into traffic (fire hydrant in the middle of the sidewalk where I got stranded). He recommended checking the fuses.
After a few minutes reading a tiny iPhone PDF, found the fuse box. Nope. Wrong side. Right side. Found the other fuse box. OK -- here we go...
...the 10A EFI fuse was fine? Contacts were a little corroded, but otherwise looked fine. While I answered a call about a guy bringing a trailer, my buddy swapped out the EFI 10A fuse with the spare (no corrosion on it).
Bike hesitantly starts back up and is running fine long enough for me to cancel the trailer help and ride home.
The Verdict?
So -- I'll leave the bike on the tender overnight. Tomorrow I'll check the voltages from the battery -- per @TownsendFJR1300 -- after everything's charged up.
What else?
Thanks,
nthdegreeburns
CODE 46
- New OEM battery within the past 3 months
- New plugs within the past 4 months
- Dual headlight mod installed
The Fuse Fix
The Verdict?
What else?
- Did swapping the fuse short the ECU and resolve the issue temporarily?
- Should I just go out and buy all new fuses so they're new?
Thanks,
nthdegreeburns
