Some various "bad days".... https://www.youtube.com/embed/5RAaW_1FzYg?autoplay=1&modestbranding=1&re
As a professionally qualified electrician I can tell you, this is wrong!
It's why the EU is so strict on wiring regs. If you reported that to the building control at the local council offices, the installer could face prison time for something that bad.
Sent from my D5503 using Tapatalk
Real story from tonight:
Go to a friends to look and see why the 16 year old addition to a ranch home lost electrical power to the "newer section of the home". I covered allot of ground and found some suspicious stuff, wires that'd been hot, nuts melted from heat, water intrusion into an outlet but still no root cause for varying outlets and lamps not working. Inspected at least 20+ junctions in the affected area. Nothing.
So I go outside wondering if someone powered the inside from something less obvious. Found a weather resistant outlet with no power and a conduit leading under the foundation. Me thinks it **possibly it could be related** so I check the crawl space the find the wire cut clean off. ** Perhaps cause its not on a GFI and the last sale said POWER IT DOWN OR FAIL INSPECTION??? ** IDK!!!!
OK - NOT IT! But then I found this little gem shoved up in a hole. It was loose so I thought a tiny wiggle might reveal a greater issue. OH HELL YA! CALL ME SPARKY!!!! Did I mention I'm in MUD cause the crawl space is damp??? Love it! Glad I'm not the jumpy kind! lol
240V AC live wire connected to NOTHING!!! MF@SSHOLES!!! What is wrong with people!!!!!!! I ran out of time and terminated it but could not access the secondary water heater to determine if it had ties to it and/or/if I could chop power too it at the mains. I mean, for all I know it was the source of power to that section that had no power and it fell out. But dear god, let us hope NOT! Gotta go back and figure it out! Crazy!!!!
Stuck a meter on the Red and Black! 120 each to a 50Amp breaker! Oh My... old water heater, Range, Dryer, Grow lamps??? IDK!
Great find! Lol! That needs proper termination in a box. Now on to find your power loss.
I've found zip cord powering outlets inside of walls! If I had my way I would require all electrical in housing to be mounted outside the walls. Yeah, I know, your pictures won't look so pretty next to that junction box so let's also do the plumbing outside the wall to give it that balanced look! :rockon:
I need to start a new thread! To anyone who has used those pingers that inject a signal at the plug or junction so you can trace back to thr breaker, does it induce a signal on the neutral or just the hot?
The hot is dead, but the N is intack at all locations.
Tks...
