twobob1
When I start my fz6 from cold I blip the throttle and it almost sounds like its running on only a few cylinders I think it idles fine its just when I rev a little, if I leave it a minute or two it starts to rev fine. Im new to 600's and just wanted to know if this is normal. Its done 26k miles and has apparently had its valve clearance check and new plugs. The other thing I've noticed is there is a a bit of vibration noise around the 2-3k rev range, I have checked all the plug leads are on properly and spark plugs are seated tightly.
My main concern is when I blip throttle a bit (like 1-2k revs not a lot) from cold it almost wants to bog a bit and doesn't sound right like exhaust stutter until a while later. Is this just the bike warming up?.
