- Joined
- Feb 7, 2009
- Messages
- 12,538
- Reaction score
- 1,185
- Points
- 113
- Location
- Cape Coral, Florida, USA
So I tore off the exhaust for the 8th time with the addition of the cat pipe. Decided to take off the headers while I was at it. Found there are only two gaskets on the headers, could be part of the problem? Going to try and find someplace that can create a better fit between the y-pipe and cat pipe...
Imgur: The most awesome images on the Internet
That pic shows it partially damaged and partially pushed down (not using all the sealing area).
The OEM seals work just fine but the pipes need to be clean/ un-damaged, round.
Putting a little bit of hand dish soap on the gaskets when CAREFULLY installing the pipes together, with the correct Scorpion clamp
will make your system tight as a drum..
