Fueltank and Hoses
Fz6Sa
SS1000 Veteran
Premium Member
Danmark, Near Aalborg (GMT+1)
www.youtube.com
Ok, So I've started on the Dual Headlight Mod tonight (The bd43 version), and I cam across this:
When I lift up the Fueltank, - I see 2 narrow hoses: The Fuel tank breather hose, and The Fuel tank drain hose, BUT ..
if I look under the Bike I've got 3 hoses comming out, - 2 of which are marked white and cut of in an angle, the third is unmarked and cut of straight.
If im reading the manual correctly, the unmarked should be the Drain Hose, and (I guess) one of the two white should be the Breather.
But whats the third hose?:confused:
My only bet is the Water pump breather hose, but I loose track of it when trying to trace it.
reiobard
Samurai FZ Soldier
Hillsborough, NH
just a shot in the dark, but the overflow?
maybe one as a breather, one for a fuel overfill, and the 3rd to drain any water that gets in around the cap if it is out in the rain?
reiobard
Samurai FZ Soldier
Hillsborough, NH
so are all 3 coming from the tank or you just see 3 at the bottom? if it is just 3 at the bottom then one is the coolant overflow.
Nelly
International Liaison
Co Offaly, ROI
Please can you post a picture, I am looking in the Haynes manual and there are three hoses.
The two you have mentioned and the fuel hose itself.
Nelly
Fz6Sa
SS1000 Veteran
Premium Member
www.youtube.com
Nelly
Ok. Let me refrace: From the tank there are 2 NARROW hoses (and of course the more bulky fuel hose). When I look under the bikr, I see 3 of these narrow hoses.
I have now managed to backtrace the 3 hose, - it ends just in front of the rear shock absorber (See attached pic).
Ya,- I know the pic i kinda har to decrypt, but its kinda hard to get a clear pic inthere.
Ive marked the tube with yellow.
Nelly
Co Offaly, ROI
Thanks Mate,
You have me stumped, I will have to go and look in the daylight.
Nelly
Fz6Sa
SS1000 Veteran
Premium Member
www.youtube.com
Pics from manual:
Hi there,
Well the three hoses seen on the tank im ok with, - I know why they are there and what they do.
The two narrow hoses from the tank runs down through the bike and ends down by the center stand. However a third hose also ends here, and its the function of this third hose im asking about.
If you look at the pic I posted, you can se the third hose, thats I've tracked to end just in front of the rear shock absorber.
