warrencycle
Daylight shot.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Looks great bro no worries about all the posts haha gets you more feed back from people cause they think its a hot thread lol. Love what you did with the exhaust. Ive been thinking of doing the header swap and a shorty side exhaust for quite some time coupled with the tail swap. The tail you used aint exactly my cup of tea but it still looks good and since you were on a budget id say out standing work friend keep it up:thumbup:
Lookin to swap this in. Any pointers on triple clamps? Would like to purchase something bolt on. Will a 2006 FZ1 triple clamp work?
I've had R6r inverted forks for about 3 years now, it's NOT a direct swap, fab work and patience are required, 03-05 R6 06-09 R6s forks are a direct swap, I recommend these if you're looking a stiffer fork, plus you can get them for a cheaper price,they are more than adequate for the average rider, good for a track day or 2 each year too..
Well since you already have the forks make sure to get the R6's Brembo master cylinder, new handle bars, you also need new custom length brake lines, brake fluid flush, new brake pads, new piston seals would be a good idea since there from 2005, plus mesure the FZ6 & R6 forks and compare lengths, can't remember if the R6 forks were shorter than the FZ's, lowering the front end more than 10mm is not advisable, it get's overly sensitive thus causing too much steering input, if lower than 10mm I recommend lowering the FZ6's rear shock to keep the oem geometry.
