Hi all! Just curious what's involved in removing the grips on the FZ6. I'm looking to install some heat-tape type grip heaters, which basically involves removing the stock grips, wrapping the heat tape around the bars and either replacing the original grips (hopefully), or installing new ones if the old ones aren't salvagable... Has anyone done this? Are the grips difficult to remove? Are they glued on? Will I be able to re-use them?
Thanks in advance for any and all advice....
Cheers,
Crystal
Cheers,
Crystal
