Headlight mod questions
Skylardog123
Georgia
Okay so i want to upgrade to leds, but also want to do the headlight mod to have 2 low beamd and 2 high beams, anyways, if i order 2 h4 bulbs, one for each side, that are both dual beam bulbs (which means kt has a higj and low beam in one bulb), if i do the headlight mod, then if i have the lowbeam switch on, will both bulbs run low beam, and when i have the highbeam switched on, will both lights be high beam?
The bulb sockets are different for each side.
The BD43 mod(do a search), plugs into the harness (no hacking-under the battery tray as I re-call) and gives you your second LOW BEAM headlight.
I don't know of any dual high beam mods.
I suspect to put a different socket (dual elements) in the plastic assembly, will require a bit of modifications...
