Se7enLC
Nerd
The last couple times I've ridden, I've noticed a problem. I put the key in the ignition, and I can't turn it. There's normally about 1cm or so of "spring" with the key - when it's all the way in, something inside the keyhole moves with the key. That no longer happens - it's like the "spring" is stuck. I have to put the key in and out a few times and wiggle it before the spring comes back to life and I can unlock the steeting.
Any ideas? Maybe there's rust inside the ignition? Should I spray something in there?
