- Joined
- Mar 6, 2007
- Messages
- 1,192
- Reaction score
- 9
- Points
- 38
- Location
- St.Joe/Kalamazoo Michigan
So, I finally got around to taking my tank off, and I must shamefully admit that it was my first time lifting up the tank. I am the type of person who does all of my own work, until it came to the bike, since I ended up with a service plan, I have just left the maintenance to the dealer. I'm more than capable as long as I have access to the required equipment to do just about any type of work on cars, bikes, trucks, I've done plenty of work on different vehicles, just for whatever reason I haven't taken the bike apart yet, which is sort of like a right of passage to me. I guess I was too busy riding it. I have changed my own oil and cleaned/lubed/adjusted cables, chain, and have maintained tire pressures on my own still. I just haven't messed with the air filter or lifted the tank until now, which is unfortunate because I could have probably stalled a problem that I encountered underneath my gas cap.
Here's what it looked like when I noticed it (sorry the pics aren't that good):
As you can imagine, with my procrastination, it was much worse by the time I finally decided to make time to get it fixed. I decided to take the tank off and take it to my uncle who does street rods/painting/body work to have it fixed. So here's a couple of pics of what I encountered in the process:
I lift up the tank and notice this:
I relax the kink with my fingers and hear a splash. Then I notice this:
That's rusty water.
Here's a drip of it still coming out:
So, I believe that in conjunction with a paint defect, this blockage of the drain underneath the filler cap assy which allows for water/overflow/spilled gas to drain out caused the corrosion, rust, and pitting I experienced.
Here's another angle of the kink:
It's worse than what my dad's cheap camera makes it look like. It was really all the way pinched closed. This has to be because the service guy didn't pull down on the drain tubes after letting the tank back down when changing the air filter (yes I checked and it has been changed).
So, make sure you do this, or you will have to have your tank repaired.
Looks goofy:
Also, this is a terrible pic, but the screws are labeled 1, 2, 3, and 4. What's it do? Am I going to need this when I sync the tb's? (I'm lazy) Also, I discussed syncing the tb's with my dad while I did this little project and I learned he owns a 4 port vac gage as required to do the job. I just have to find it in the garage (they've moved within the last year, so wish me luck)
Sorry I don't have any completed pictures right now, I'll have those this weekend when I put it all back together, but he took and used a sandblaster (after taping everything off) to clean the area up and used 2 coats of self etching primer, and then some glossy black over that to cover it all up. Then we put a little grease on the contact points between the tank and the filler assy. You can't tell once the filler cap assy is back on the tank. It should last a long time as well.
The last thing I did is adjusted the throttle cable down on the left hand side behind/in between the frame. The jerks at the dealer just ran the adjustment up on the handlebars right off the end of the threads when it was a little loose last time I had it in.
So, pull down on your tubes, so they don't get pinched, kinked, or likewise.
That's rusty water.
Looks goofy:
