Oh I've been narrowing down. Keep in mind I work of the State so there are very formal rules that apply. There is also a thing called Open Records Request, in other words a person can request a copy all of the work that I've done during the selection process.
Here's the numbers:
121 applied, 59 are "qualified", per State rules ALL 59 have to be interviewed unless I apply a secondary screen criteria. So I developed five attributes that are key to the job and assign a point catagory to each of them. Then I wade through all 59 applications and score each applicant. Then I look for the "natural cutoff" in the scores. The result was pretty bell curved. In this case it was 15. One person I'm unable to contact hence 14 to interview.
During the interview process there is a set of questions that have to be approved by HR prior to beginning the interviews. That way each person is presented the same questions and the process is considered fair. Each question has a point value and depending on how they answer each question they receive X number of points. The people with the highest point totals are extended an offer. If they accept then the back gorund screening process begins. If a person is not selected HR will notify them.
Yes these are all for the same position, Legal Assistant/Paralegal. I have had a wave of retirements, some planned, some not planned, but all good if you know what I mean.
When I've hired in the past I've only had 4 to 5 applicants. In this case I have a nice mix of people; some with 20 years experiance, others with 3 to 5 years, all appear to be very good, at least on paper.
You can't (perhaps are not allowed to) narrow it down more BEFORE you get to the actual interviews? Sounds like a huge waste of everyones' time. Well, except one persons! A 14 to 1 ratio for the actual interview is crazyness.
EDIT...you said three, not one. doh! I guess that is not that bad. All the same position?
How will the offer/no offer process be administered?
