I had both seals start leaking and replaced them 1 month ago. The list of parts that I changed is below, pricing was from
Ron Ayers
4TX-23125-B0-00_____METAL SLIDE 1_____2_____$5.02_____$10.04
4TX-23135-B0-00_____METAL SLIDE 2_____2_____$5.02_____$10.04
4TX-23144-01-00_____SEAL DUST_____2_____$5.70_____$11.40
5VX-23145-00-00_____OIL SEAL_____2_____$4.50_____$9.00
90430-10171-00_____ GASKET_____2_____$1.35_____$2.70
Subtotal $43.18
Standard Shipping +$9.00
Total $52.18
It took about 2 hours to complete. You will NEED:
- A 43MM seal driver. Brand new around $50, or you might find one used. If you are on good terms with a local bike shop you might be able to borrow one. Some will say "You don't need a driver, just use a hammer and punch". If that is your approach, don't be surprised to find your new seal leaks shortly after you put it back in service. Proper tools cost $$$, do it properly or don't bother at all.
- Some type of tapered bit to hold the damper rod from rotating while you disassemble and reassemble the inner fork package. An old 7/16" socket, 1/2" drive will work. Sand or grind the O.D. to approx. 5/8" at the end. You will need a long extension get the socket down into the damper rod.
Once in place, you loosen the socket head cap screw on the bottom of the outer fork tube. You can use a piece of pipe or anything similar, just be sure it is very clean as you don't want to contaminate the fresh oil on reassembly.
- 1 liter of fork oil of your choice and a very accurate fluid measuring container. A graduated 1 liter plastic beaker can be purchased for about $5.
Keep everything clean. Get all of the old oil out. And consider checking your steering head bearings if you haven't done so before.
Good luck.
