Chaosratt
Senior Member
Im a bit confused, last time I tried I couldnt get the bike to do a damn thing on the center stand. Its just like the side/kickstand, it will only let the engine run in N, at least on mine it seems.....
Hay Jonac,
Can I be critical about it?
Of course I think it looks great on the bike and you sure did a super super job at installing it on the bike but did you consider sinking the unit into the faring so you only have the digital display (front section) visible while the remainer of the unit was hidden behind? If you did then obviously its not possible to do this, I'm not familiar with the unit so I'm just throwing out an idea!
Reason why I ask this is because I may well buy one for the bike but I'd be more in favour of having the unit flush with that part of the faring.
jonac ...what grips are you running??? where did you order them
are tehy comfy???
very nice
Is this indicator always accurate? Does it show erroneous reading after a while?
Don't tell me that you don't do mirror and shoulder checks...
I have just installed my new Acumen Gear Indicator. I have some question when I put on the first gear the original indicator neutral light still light up until I release the clutch it will turn off. Everytime I put on the clutch the neutral indicator will light up. Is this normal? I don't think so. Or should I unplug the white connector with the light blue wire? :rtfm: Your help will be highly appreciated
I installed mine yesterday and tried it out today, but i've noticed that whenever i pull in the clutch, the neutral light comes on on the main instrument cluster. Is this normal, or have i wired something up wrong? The indicator works perfectly otherwise!
Happy New year mate, When you back from your posting.Seems like you've resolved your issues ... no problems at all with mine
