luckyirishboy209
custom fz6 foot peg maker
is that mod of the year; plug and play or do you have to soider some wires?
The acumen mod is not plug and play. It is for some Honda bikes as the person doing the mod has a Honda and know which wires to spice into in the instrument cluster. My cluster has a separate connection coming off the back for the Acumen. The wire is ran down the left side of the bike and soldered into the ECU harness under the tank. If someone knows which pins on our cluster connection is neutral, speed, and tech, I could then solder the acumen wires directly into the pins from inside the cluster and then it would be plug and play.
Now I rarely use big words .... but: GREAT JOB DUDE !!!!
Must have taken you a little more than 30 minutes, - How is the exhaust pipes holding up? I reckon you used a heat-resistant coat, but is it holding?
Once again, - the hat comes off in admiration!!
Are those what Scorpion exhaust tips look like now? or is that a custom or factory mod that was done on your cans. I like everything about Scorpion Exhausts, except the look of the tips. Your cans look more like Two Bros ones, which I like the look of much more. If this is what Scorpion exhausts look like know, then I'll feel good about getting those. Great looking bike, you'll put the rest of us to shame!
