BD43 / Dual Headlight Mod - Best tutorial?
MIJ_FZ6
USA
I've been meaning to do this mod. I don't mind splicing/soldering. Every time I look up the process is get discouraged because the posts are so old and do not have pictures. I'd prefer to have the method that disables the lo-beam filament when I put on the high beam.
From what I can tell, connect this "empty" terminal to the "empty" top terminal of the right headlight plug right? Here is one post that looks promising: https://www.sportbikes.net/forums/fz6-fz6r-mods/297604-dual-headlight-mod-without-splicing.html
This guy is tapping into an existing green wire, I have a feeling this may not be the right way:
See my post #9. https://www.600riders.com/forum/fz6-mods/57092-dual-headlights.html#post627614
Edit: just checked out that video. Yes, its the same as the way my bike was done. The green wire at the left handlebar runs back under the tank to a connector, then the bd43 harness plugs into the connector. Same end result, just the bd43 method is a little "cleaner"
When I removed my HIDs and went back to this, I added a switch like this on the inner fairing, so I could shut if off if I was using heated gear.
https://www.amazon.com/gp/aw/d/B00O...g_1?ie=UTF8&psc=1&refRID=FA336J8B7KBYGK0E9A97
Thanks for the info. The BD43 mod connectes to that terminal photoed in the first post vs splicing into the handle bar cable right? That is the only difference?
