[MENTION=2579]Motogiro[/MENTION]
Will the coil collapse take out the LED in the gauge? It may be wise to fit a 1N5003 diode in there to shunt the energy to ground when switched off High Beam to protect the LED.
Also, if someone builds the circuit to the diagram above, and for example the relay failed. Its off state would allow LB operation unless the contacts burn. In which case, a pre made jumper (male to male spade) could be inserted to power the LB lights w/out the relay. Keep that in mind when making wire connections. Build a mini jumper!
