Started the bi-xenon HID conversion
I had the rare opportunity to work on my FZ6 today, so I finally started my bi-xenon HID conversion. I removed the front fairing and headlight assembly, tossed it in the oven for 20 minutes at 200 degrees, pulled off the lenses and installed the projectors.
Observations so far:
- I should have probably heated it up a little longer or hotter, as I really had to use some muscle to get the lenses off of the headlight housing.
- The kit I got is really nice. I love how small the ballasts are. The projectors are truly universal for different sized bulbs. They both came with the H4 adapters installed, but they threw in H7, H1, and 900x adapter rings too.
- I see a small hairline scratch on the outside of one of the lenses. I hope it's not noticeable in the beam when the light is on. I doubt it will be, but I'll find out, once I "test fire" the lights.
Questions so far:
- Inserting "stopper" washers on the inside of the housing to get the projector to not go too far into the reflector housings. I see mention to this, and I had to do it too. They kit came with the washer pieces to use for each bulb size, and I wrapped it with black electrical tape to keep them from scratching up the reflector housing that I'm not painting. Did you guys do the same type of thing? The larger washer on the H4 side makes that projector appear to stick a bit further out of the housing than on the H7 side. I suppose I could grind down the H4 side stopper washer to be smaller to alleviate this, since I have two of them and am only using one.
- Routing of the wires for the halo power and the high-low beam blocker. Since the originate on the reflector side of the housing, I have them stuffed through the little notch where the old bulb retention pin used to clip to. I really see no other way to run the wires, but I don't recall this being mentioned, or seeing pictures of those wires.
Anyways, I'm excited to finally get this mod started!
p.s.- Yesterday I added an auxiliary LED brake light strip to the back of my Yamaha tail rack. I had concerns about visibility of the stock brake light when being followed by a tall vehicle, so hopefully this will help out. The strip was only like $2 shipped from China, so it's a low buck mod.
