So rode just less than 5 minutes away to a store, and when I got back on my bike to leave, the bike would not crank. Just the red oil light would stay on, no fault code at the beginning. The fuel pump came on, because I heard it. I wiggled my engine cutoff switch multiple times, but it's a new switch so I doubt that it was the problem. My engine sounded fine prior, no ticking and the Crankshaft Position Sensor is less than 40k miles on the clock as it was replaced. But I was very concerned with the fault code.
I started to remove my seat and go through the process of lifting my tank up to disconnect the battery and hopefully reset everything. But since I was in the parking lot, I decided to walk my bike about a 100 feet to seek some shade. For the heck, I decided to crank it up and it did.
So what do you think was the problem? Did moving the bike in neutral adjust the position of the sensor or something? I rode home immediately but now I'm scared to death to go anywhere.
