bigborer
Had to also buy an impact wrench to remove the clutch nut, as it was impossible to remove using only a wrench and the holding tool.
So far I've found:
-some wear at the clutch pressure bearing
-(little) wear at the clutch collar bearing
-water pump rubber o-ring got a bit shaved off while pulling the water pump
If anybody knows any reliable online shop shipping from inside the EU, please let me know.
One thing that concern me: why is there that black marker letter at the clutch region inside the engine case? I don't think Yamaha factory workers from Japan are made to mark the QC with marker pens...
So far I've found:
